Yesterday, I noticed the speed sign readout was not reading. Because of that I noticed the navigation was not working as well. It had the truck located on the other side of town. Went through all the settings and everything looks to be where it should be.
The system recognizes and reads the SD card, ejects it properly, and reloads it.
Thoughts?
welcome to the glitches of these newer trucks...i was on a road trip and half way back that happened...it took parking the truck for a gas stop so lets just say 10 min for all to come back online.  ...before that stop i pulled over and just cycled the key, stopped and turn off then back on, and that did not fix it.  i have had the navi just lock up and not work until a couple of truck cycles.
    xdieselmechanic
    xdieselmechanic
  • Who's Online   1 Member, 0 Anonymous, 603 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
