I have a 2003 Chevrolet Silverado 2500Hd 4x4 with 6.0 LQ4, 4L80e and manually shifted transfer case. Burned up the transmission so I picked up a used 4L80E out of a 2004 Suburban 2500 with the 6.0.
Well finally get it installed and during the installation, had 1 plug I could not figure out where it went to. Well after scratching my head for a few days discovered the replacement transmission is missing a speed sensor. Swap it over from the old transmission.
Take it for a drive and no speedo. Anyone run into this before?
Speedo is run by the sensor at the back of the transfer case.  IIRC from when I converted my truck from 2 to 4wd, the 2wd 4l80e has a sensor at the front and a sensor at the rear, and when converting it over, the sensor on the front is still used/plugged in, and the sensor in the rear isn't used anymore, the plug that would go into it, instead plugs into the 4wd harness, which then plugs into the sensor at the rear of the transfer case (it's basically a short extension cord to that sensor).
The harness in my truck has plugs for both front and rear on the transmission. Also none of the harness is modular, it's all one piece. So there's no 4wd harness per say, it's just part of the engine harness.
The truck the used trans came out of was the exact same drive train (engine and transmission) other than being a year newer and a suburban not a silverado.
Having a '06 2500HD, and from doing a lot of research on how the 4wd setup works on that generation truck, yes, it is modular.  The 4wd harness goes from the front diff,  up to the engine fuse block, where it plugs into the main truck harness and has ground point, then back to the the transfer case, and makes a U going forward to plug into the end of the harness going to the transmission (namely, the plug what would go on the VSS at the end of the transmission if it was a 2wd truck).
It plugs into the rear of the transfercase so that it can read the actual vehicle speed.  If it used the transmission output shaft speed, it would need another sensor to know whether the transfer case was in hi or lo (which it doesn't have).
Ok, this is my first Silverado. I dont have any plugs on the rear of the transfer case. I will have to look again.
Davester, thank you so much, that last post helped so much. I figured out that the plug I have a picture of above went to the plug for the second speed sensor! Plugged in and issue is fixed! Thank you so much again.
Second speed sensor?  The sensor on the front of the TC, above the manual shift lever, is the 2wd/4wd mode sensor.
There's no VSS sensor on the rear of the transmission (or at least, it's not used, my '06 has a plug that goes into it instead of a sensor).  The harness along the transmission plugs into the transfer case harness instead of where that plug goes.
So....the transfer case harness had the second plug off of the VSS in the transfer case that just looped back to the plug that would have plugged into the 2nd VSS on the transmission, had it been there.
But as soon as I plugged that plug on the transmission harness to the transfer case harness, the speedometer came to life the abs light went out, and the service brake system message went away. The transmission now shifts properly too.
Thank you again for your help. Doing all this work (new engine install, transmission replacement, new fuel lines, etc) all solo I was bound to miss a few things.
    250.3k
    chfkief
    chfkief
  • Who's Online   3 Members, 0 Anonymous, 1,673 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
