Read up on tuners, "chips" don't exist anymore and haven't since the EPROM days of the early 90's.
It's a well covered topic for the last 15+ years on many different forums. Diablo, HyperTech, Superchips, BullyDog etc all make handheld tuners.
    Frank V
    Frank V
  • Who's Online   6 Members, 0 Anonymous, 1,043 Guests (See full list)
