4.8 hard to start
My 1999 4.8 is getting harder to start since a couple of weeks. There is no problem starting when cold or very hot, but when I try to crank it up after 5, 10 or 30 minutes, it's taking a while to do so, maybe 6 to 8 seconds, and then it's runing rough also for a few secs.
From what I've been reading in the Helm manual, this could be caused by the MAF, the ECT or the IAT.
If I have a dirty MAF sensor, I'm wondering if it could be cleaned and what is the procedure to do so. Any ideas would be welcome.
Thanks
Stef
I had a very similar problem. It was the fuel pressure regulator. To see if yours is bad, pull off the vacuum hose. If fuel is present, replace the regulator. Good Luck!
This afternoon I pulled the vacuum hose connecting to the fuel pressure regulator
and fuel was leaking a lot from the the tube, guess that was the problem so I ordered a new regulator, going to get it tommorow.
Thanks again Marman! :loser:
Stef
