I’ve got a 2015 GMC Sierra 1500 (5.3) with 165K KM. Check engine light is on and it’s the catalytic converter. Just got off the phone with GM Parts: quoted $3672 CAD for a new OEM cat -just the part (y-pipe - 3 cats). So that’s not going to happen. This truck has become a money pit in the past 12 months and I need to reign-in the costs.
A few questions:
1) Aftermarket cats are about 1/2 the price. Is there a brand you guys recommend … like Magnaflow?
2) When the vehicle throws a code (for cats), typically which cat is it? MagnaFlow also sells the third cat for about $400.
3) Any other options? Thought about deleting the cats altogether, but then I’ll need to get the truck tuned.
4) Aftermarket cats should meet or exceed OEM specs - it won’t keep throwing codes will it?
Thanks guys!
Edited by laminarflow
P0420 is drivers side.
P0430 is passenger side.
Some aftermarket cats work okay and some don't, it's such a toss up nowadays with product quality. Hard to say if the aftermarket part you buy works without a hitch.
If the truck isn't down on power or anything you could just run it as is too. The light will just stay on and the remote start won't work anymore. Could also get a cheap handheld OBD2 scanner and keep resetting the light, might take a while for it to keep coming back.
Edited by CamGTP
I have been driving with it in this state for a while. Takes 2-3 days for the code to return. Sometimes the throttle can be a bit mushy/vague which is a symptom of cat issues. The truck is otherwise in immaculate condition; just been an expensive year (new AC condenser, new rad, transmission rebuilt ... now this).
There are aftermarket cats for around 500$ (for example walker). Those are the complete Y-unit with all cats. I don't know about workshop prices in your country, but it's around 1h of work to change.
I would go with that.
What are the fault codes? What exactly is broken about the cats? If you have a leaking injector, the new cats will also go bad quickly.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,146 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
