I drive a 2013 Silverado 1500 with a 5.3 V8. Every time I start my truck, I get a message on the dash reading "Low Coolant Level Add Coolant". The coolant level is not low, and I do not have any visible leaks. My first thought is a bad sensor, but after spending hours on the internet I cannot seem to find the sensor and new reservoir tanks do not seem to have a float in them. Any help would be appreciated!
i thought it was in the overflow tank - is that at the proper level?
Edited by Bleepster
It is, right above the line when cold where it should be. It may be in the overflow tank, I just can’t find any information on it anywhere.
For anyone who may have this issue in the future, I finally figured it out. I replaced my interior climate control unit since the buttons stuck. I believe the replacement I got must have come out of a 2014 Silverado 2500. The 2014 Duramax's had a coolant level sensor, the 07-13 1500's do not. That sensor must run through the Climate Control unit because after plugging the old one back in, the message went away. My local Chevy dealer could not figure it out either, however, because that particular message is not one that is listed for the 2013 Silverado 1500. So long story short, a new climate control module out of a 2012 1500 solved my problem. It was never an actual issue with the coolant system, just the lack of a sensor causing the message to appear.
    KP1
    KP1
  • Who's Online   4 Members, 0 Anonymous, 771 Guests (See full list)
