Hello,
I made my first post yesterday in 2019-2023 silverado trouble shooting but i don't see may post in the forum or new content?  Am I limited and not able to make a new post or maybe i put it in the wrong spot?   Or maybe it'll have to be approved by a mod?
Thank you for your help.
Welcome!
Your post is there. In fact you got a reply
Edited by txab
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 0 Anonymous, 763 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
