Evening Gents
Seeking advice, guidance and knowledge. I currently have installed the Rough County 6” kit on my 2021 chevy 1500 trail boss. I have the extended struts in the front and blocks in the rear. I’m looking for a tad bit more height without breaking the bank. I have been looking at various 1.5” and 2” add-a-leafs for the 19-22 rados. I’m curious if this is a good route to go for a little more lift in the rear that is cost effective. If this is okay to do will I need longer u-bolts or as most aal kits state you would not need longer u-bolt if applying to factory stock truck. I plan on doing a 2” lower strut spacer in the front to level it and gain around 8” overall lift. Seen guys do similar combination on fords and Tacoma’s but haven’t heard anyone run that kinda set up on the new silverados. Any advice or incites would be much appreciated.
Thanks in advance
It is recommended NOT  to reuse u-bolts.
Not being familiar with the lift - but it might already include some amount of height gain through spacing in the strut assembly. Adding an additional spacer might over extend suspension geometry angles either ball joints or CV's.
Cognito has a Deaver pack add on that can gain 1-3". The bonus is it makes your leaf spring a progressive rate (replaces the overload leaf) and better ride. Add a leaf usually makes for a more harsh experience unless under load. It's $500. Cheaper than new leafs but probably more reliable than a taller block or a stiffer add a leaf.
BDS' is also releasing a coilover conversion for the rear end under project Velocity this year. Lot of room for lift.
I appreciate y’all responding, I have already found several leafs I’m looking at. Biggest question I have is it okay to stack a aal on a 6” lift block? If any what concerns are there to go with it? I have all the drop brackets for all the lines and have plenty of slack for a 2” lift gain.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,254 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
