Hello. I have a 2021 silverado with the 6.2 in it with 12000 miles. I have been having trouble with the truck since  shortly after buying it. Of course the dealer is saying nothing is wrong. The truck seems really sluggish. I've been hearing a loud ticking sound from under the truck that at times I can hear from a good distance way. It sounds like a clock ticking. Another problem I'm having is there's times when coming to a stop the rpm drops really low like the truck is gonna die. The truck doesn't like hills and starts to whine sometimes and there's quite a bunch of vibration.  The dealership says there's no check engine light and that my exhaust is causing the vibration even though it shakes when stoped st a light.
The ticking noise in the video I wouldn't worry about it my 2019 5.3 has the same noise and has done it since new. I hear it on first start after driving it and everything is warm its gone. Do you have a aftermarket cold air intake as I have heard of those issues about the idle you are saying.
Edited by Silverado4x4
The truck is all stock except for a aftermarket muffler. The ticking like a clock never goes away I can drive for an hour and it will still be there.all this started after being in stop and go traffic the motor started to die then the truck jerked forward but it was like the motor and transmission bound up the let loose with a big bang under the center console and the whole truck felt like it twisted.
Not normal. I really could not hear the ticking in your video but the truck has no power? Truck doesn't like hills? Motor and trans bound up? A T1 with a 6.2 should have tons of power. My 2021 with a 5.3 has lots of power. I would take your truck to a different dealer and talk to the Service Manager. You need to have a Mechanic test drive your truck with you so you can clearly demonstrate the problems/symptoms you are having. Write down all the problems you are having so you can clearly describe all the symptoms. The dealer you took your truck to the first time sounds like they don't give a s**t about you or your truck. If you cannot get some help from a different dealer then you should contact Chevrolet Customer Service.
This is certainly not what we like to hear, busta350.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2021 Chevrolet Silverado. To do so, please send an email to [email protected] with ATTN: busta350/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
I've taken the truck back twice for this same problem. They say they can't replicate te problem. This truck vibrates and has funky shifting all the time and not close to the power it had when I bought it. I got told to dive it till it breaks down so I get stranded. I used to average 14 mpg going to work now I average 9.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
