I have a 2014 Sierra with the 5.3. Wanting to get a cam installed and delete the AFM system to help with reliability. From what I have heard BTR cams are the way To go on these trucks. I found this kit for a BTR cam and AFM delete. Are all the parts in this kit what’s recomended? Anything else I should do while Im in there? Let me know if you think some of these parts should be swapped for anything better. Here is the kit I am looking at. https://www.glennsautoperformance.com/products/btr-gen-v-2014-gm-truck-dod-delete-kit-w-btr-truck-cam-kit-l83-l86-5-3l-6-2l
also while I’m on this topic can anyone speak for whether other mods like headers, CAI or l86 intake mani would be worth it for power before I get a tune?
That kit has everything you need. I just cammed my truck 5000 miles ago with a BTR cam. It is great. I would recommend getting the revised oil pump for the 5.3/6.2 engines. I did for peace of mind.
Headers and a CAI will complement the cam. Don't need anything fancy for the CAI, just the AirAid MIT and drop in filter. Some people like the L86 intake, some don't. I would put it on, probably pick up some torque, and you get a bigger throttle body.
  • Thanks 1
Thanks for response . So would you just go with that kit or are there better parts to use where I could spec my own kit out .
The kits are good, because they include everything. Some guys complain about the LS7 lifters, I have had no problems. You can upgrade to Johnson lifters, but I believe they are pricey.
You can also call BTR and they will explain all the cams and options and steer you in the right direction for what you are looking for.
  • Thanks 2
Since you have to take the brake vacuum pump of anyway.  Go ahead and buy the pulgs and delete it.  So you don't have to worry about it going out and sending metal through the engine.
  • Thanks 1
you can piece the kit together yourself. all of the big shops like texas speed, ams, BTR etc just charge you for the time to put it all together.  you can go to rock auto and put it all together yourself like I did and save yourself a lot of money.  the only thing you have to buy from a shop are the plugs that fill the oil holes under the VLOM.  I doing all this currently for a collapsed lifter.  I'm deleting my vacuum pump and having them install a new oil pump since I've gotten the Po6dd code a few times.
  • Thanks 1
  • 2 years later...
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,087 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
