Hey folks, I have a 2020 Silverado 2500 High Country Duramax. Last Oct a service warning came on advising me to service the park brake. Truck had a little over 35000 so I knew we had a warranty issue. Took to the dealer, they said it needs a new module, parts on order, safe to drive. Well, a few days later the Park brake lock on while I was backing up to hook up a trailer.  I had to disconnect the battery to release the brake. Took to the dealer, sat there for a month waiting on parts. Fast forward to now, while driving I strated to smell that familiar brake burning smell. Damned if the park brake didnt come on again. To supply as much detail as possible, the park brake light only comes on when I park it on a grade or activate it myself. Anyone run into this before? Thanks for listening.
This is certainly not what we like to hear, GregGreg123.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2020 Chevrolet Silverado 2500. To do so, please send an email to [email protected] with ATTN: GregGreg123/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
    d.lowrey
    d.lowrey
  • Who's Online   0 Members, 0 Anonymous, 3,800 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
