I have a 2020 Sierra with the 3.0 Duramax and 18k miles. I've owned the truck for 1.5 months and it's been at the dealer for the last month.
At first they said the turbo actuator was bad so they replaced it and that didn't fix the issue(CEL on with associated codes). So now they are in the process of replacing the turbo. They've been in this process for 2 weeks. Talked to them today and they said they are having trouble getting the turbo out. So that's fun.
Has anyone hear of a bad turbo this early before?  According to records it had drivability issues off the delivery truck and eventually they replaced a ECU that fixed the problem.
Should I be worried that I got a dud?
I had a real nightmare with my 2020 3.0L diesel.  You should be able to find my posts on this forum.  What code did you get with the CEL?  My truck was fine till 75k, then blew the motor, then went through 2 new ECMs and 3 new turbos before GM finally agreed to help me buy a new one.  I think it was some kind of electrical glitch causing the turbo code.  I don't remember what code it was, but if you post it I should be able to tell you if if was the same as mine.  Something about turbo position not learned...
Stripped / cross threaded  / loose bolts resulted in some 20 and 21 turbos needing to be replaced.
Don't recall there being a rash of posts about this.
This was from 2020...might be related.
Loose Turbocharger Actuator Bolts
October 13, 2020
Some 2020-2021 Silverado and Sierra models equipped with the 3.0L turbocharged Duramax diesel engine (RPO LM2) may exhibit a lack of performance along with DTCs P003A (Turbocharger Boost Control Position Exceeded Learning Limit), P0046 (Turbocharger Boost Control Position Performance), P0299 (Engine Underboost) and/or P0234 (Engine Overboost). If these conditions are found, check for loose bolts on the turbocharger actuator. (Fig. 18)
F18-bolt-1.pngFig. 18
If any of the three actuator bolts are not fully seated (Fig. 19), the threads may be damaged and the turbocharger should be replaced. The actuator is not available as a service part.
If all the bolts are fully seats, continued with the diagnostics outlined in the appropriate Service Information.
F19-bolt-2.pngFig. 19
Edited by redwngr
2021 Silverado 1500 RST 4WD Duramax at 45,500k. The Nitrogen Oxide sensor took it to the dealer; they need to replace the turbocharger. I also had problems with the push-button starter not wanting to crank over; it made noises as if it were trying to start, but I couldn't stop it.  It had to stop on its own, lasted for a minute, felt like longer than, tried pushing the button again, and it would start.
I feel like I'm going to have issues down the road?
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 849 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
