Limited Slip??
I've been thinking about getting an aftermarket limited-slip differential for my 89 Sierra to improve my traction in snowy and muddy situations. does anyone have any advice on if this is a good idea and worth spending the money? Thanks for any advice.
Cheers
Welcome to the forum. A locking differential would be best for those situations you mentioned. A limited slip would not be recommended. It is money well spent if you get into those situations a lot.
If money isn't an issue an ARB air locker is nothing but cool. Fully locked when you need it, open diff when it's disengaged. If you don't need or want something like that a GM gov-lock isn't a bad way to go. I had a '92 that I found one for that came from a wrecked '98. I gave 60.00 for the entire center section of the rear axle assy. Swapped diffs over in a couple hours.
Thanks alot guys, I think im gonna go with the locking for sure, another quick question, are locking diffs only used on the rear diff or can the front also lock? any input as when you guys are all using as far as diffs goes would be cool.
cheers
Now to get technical, whats an ARB? I read somthing that said that aslong as the truck has locking hubs on the front or front axle disconnect a front locker would work. Does that sound right?
thanks :cheers:
An ARB air locker is a differential that normally operates is open diff mode then when you turn on a dash switch it puts air to the diff to lock it fully, no differentiation. The reason these are not nearly as popular is it take a air compressor to and air plumbing to install.
ARB is nice if you have the cash and air system.
Myself and a number of others I know are running Auburns. A unique set up for a limited slip. And work awsome.
It's inexpensive and quite heavy duty.
And the latest bonus, the new Auburn rebuild program.
When you need to rebuild other limited slips a kit runs you about $100.00 plus labor to pull the diff, tear it down, install the new parts, re-assemble and reinstall.
Auburn now offers a 4 year program, if it fails in 4yrs the will provide a complete unit for less than $100.00. Not a bad deal.
I've had mine for a year and a half and I am impressed with this system. It's quiet, allows freedom around the corners put some torque down the staft an she'll lock solid. :cheers:
The harder you push it the more solid the lockup.
I've had mine for a year and a half and I am impressed with this system. It's quiet, allows freedom around the corners put some torque down the staft an she'll lock solid. :loser:
You must have good luck. :mad: I replaced mine three times in less than a year. The third one, still running it, is totally open now. The Auburn units will only pull both tires if they have even weight on them. They are great for hole shots and flat muddy areas. If you get weight off one of the tires the other one won't pull. I like the lockers a lot better. They will pull even if one tire is totally off the ground.
Had an auburn in an 85 K5 blazer--smoked it in about 2 months. When it was new it made it a little squirrley due to the short wheel base. I still like the factory gov lock---lots made so you can find them in a salvage yard and very durable.
I did some looking around and found found the Powertrax Lock Right Locker, has anyone ever used it? it looks good on paper but is it good in the mud and snow?
www.powertrax.com is the website. it says it can be used on the Front diff too, as long as there is a front axle disconect. would my 89 have that?
The Lock Right looks like a good unit. If you plan on doing a lot of daily driving it may be too noisy. (noisy ratchet) They have a no-slip unit that appears to be better for daily driving. Summit Racing has the locker for $289.00, not sure if they carry the no-slip one...
:loser:
