I have a 2021 silverado with about 31,000 miles on it. 5.3 V8 with the 8 speed transmission.
I know these trucks have issues with DFM AFM and lifter issues. Although this truck is not equipped with this option(because of the chip shortage) but I believe the lifters are still the same type.
I do not think it's a lifter tick. I think it may be from the "high pressure fuel system". Not sure just seen that somewhere gm put out a TSB about the fuel system making noise.
I attached a video of the noise. It sounds like a clock ticking and is kind of a background noise.
Edited by Everett Granger
  • Everett Granger changed the title to **Updated video** 2021 silverado 1500 Z71 RST Clicking noise! Help!!
You could be hearing the purge valve ticking. Grab it and see if it feels like what you are hearing.
Travese's have a TSB on a foam damping kit for the ticking sound.
What is the purge vale for? And where is it located usually?
It is used to purge gas vapors from the charcoal canister into the engine. Emissions stuff. Not sure where it's at on your motor but look it up on Rock auto to see what it looks like.
Hi repair man, I have a 2020 Chevy Silverado 1500 V6 turbo I'm at 120,000 km recently. The last two weeks I started to develop a ticking noise. Originally I thought it was lifters but it is not lifters. I took it into my local Edmonds GM dealer. Nobody there had a damn clue what it was. They decided to give me the option to start tearing apart my engine, which as you know that is an extensive research with no guarantees. So they took a shot in the dark and said let's replace your high pressure fuel valve $1,200 later. The tick is still there and my truck is still running like crap sounding just the same. I'm frustrated I've had this truck for 7 months up and it's disturbing that a GM dealership has no clue what their own species of truck is doing. Can you please please help me decipher this?
    d.lowrey
    d.lowrey
  • Who's Online   3 Members, 0 Anonymous, 4,314 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
