Don't know where else to submit this, so:
Currently, when enabled, the option to tilt exterior mirrors downwards when in reverse enables a driver to easily see their truck's rear wheels when parking. This makes perfect sense, except when a trailer is attached. In fact, I can't think of one instance where someone would want to be able to see the rear wheels of the truck when reversing - we want to see the trailer wheels. Right now, you have to remember to go into Vehcile Settings and disable the option whenever you have a trailer attached, then remember to put it back when you disconnect the trailer.
The change I propose would certainly go along with the "Better Never Stops" slogan on OTA Updates. And, I think this can easily be implemented, with a simple insertion of an If Statement Branch into the existing code logic, something like this:
If Trailer attached
   Don't tilt mirrors
Else
   Tilt mirrors
EndIf
An interface option would not even need to be added. Simply adding, "Except when trailer is attached" to the existing text in the tilting mirrors option under Vehicle Settings would suffice.
It's so simple, maybe it can be in the next OTA update. 🙏PLEASE?
Edited by MrLeadFoot
Good idea.
If (MirrorTilt and Not TrailerAttached) Or (MirrorTilt and TrailerAttached and TrailerTilt)
      Tilt the mirrors
EndIf
Edited by reeseb
You realize this is NOT any kind of official GM site right?
  • Haha 2
When you find the correct area to submit a request, reply back here or add to this to your list....
DELETE the flashing lights when you drop the tailgate, using the tailgate button!
Yes, we realize this, but we know GM folks unofficially see some info posted here, so better to make a request public on the off chance someone might see it and pass it on to someone who cares.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
