Freezing doors!
It's in the single digits here and my doors get froze to where I can't open the doors! Sucks! I've heard of putting something like Son of a Gun on the weatherstriping to help this, but is there anything else that works better? Any household things like Pledge or something? Babyoil?
I've always put a layer of silicone belt dressing on the rubber door gaskets. No problems with freezing. But of course, when there's an inch of ice on the truck, nothing works except a chisel. :loser: Chris
After a car wash in winter I shut my doors just one click and turn up the heat. This lets the weather stripping dry out.
At the begining of winter I take some heavy duty silicon spray lube and soak a rag with it, then use that to wipe down my door seals. I also do this very lightly where the window glass seals in the door so that I can roll down my windows at the atm.
Can't remember the last time my doors froze shut here in Florida :loser::mad::flag:
Wouldn't a thin layer of household vaseline do the trick? As far as I know it doesn't freeze and wouldn't likely wear off.
That's what I do.
Hey Stebob...That you over at ATVConnection?
