Lifted 'Burban done
Well, folks, it's done.
I added a 3" body lift from Performance Accys and a set of H2 tires/wheels (315/70-17s) from eBay. All totaled, around $700!
So if you're thinking you need new tires becasue yours are worn out, think of this path before spending $800 for replacement tires alone!
Ed in Chicagoland
2001 K2500
:devil: Do you ONLY have the body lift and you fit 315s?!?! I thought you had to have suspension and body for that setup? I just received the f0rD torsion keys and getting ready to do the body lift, I would LOVE to be able to go 315 in that case!!! Has anyone else gone stock, body lift, and 315s? :chevy: Sweet ride man! :D
I've got a 2001 Tahoe Z71. I installed a 3" PA body lift and ford torsion bar keys and am currently running 315/70R17 BFGoodrich All-Terrains on the stock rims. The fronts don't rub except on full lock to one direction on the driver's side cab side not bumper side (I can't remember which direction) but that is only the plastic wheel well so no biggie. The rears however rub on some metal suspension members whenever the rear axle is torqued. I'm trying to determine the best solution at this point to get rid of the problem.
Check the link in my signature for pictures.
B.J.
Ed in Chicagoland
2001 K2500
Ed - Suburban looks great :devil::D
Thanks guys!
It was worth the effort and everyone likes getting a deal on wheels/tires from eBay!
The tires don't rub on the back axle at all. On the front, they do SLIGHTLY rub the inner wheel well plastics on hard turns. It's so slight that I don't care and it's not worth removing the plastic. I tried tweaking the t-bars but it didn't help... those 315s are just plain'ol large.
I would recommend it to anyone! (and I'd help if you lived in the Chicagoland area!)
Ed
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
