Looking to order a 2024 Chevy 2500 CCLB, 6.6 Duramax, Lt, with the Z71 Sport Edition.  Have my mind set on the Lake Shore Blue Metallic color, however, when I visited the dealer and we went to put the order in I was informed that the color is currently not available-with no target date of availability insight.
My question is does anyone on here know of when Lake Shore Blue Metallic is going to become available to order?
Thanks.
Edited by Robbie R
Local dealer tells me August is first order capability for the blue GMC and Chev... but who knows how many times that will change.  Real bummer too.  I'd really dig a blue AT4.
I was originally looking at AT4 but you cant get the blue as a color option.
From what I am told GM is having issues with paint suppliers. Flint obviously has issues but the Mexico built Equinox I had ordered earlier this year was cancelled due to paint constraints. Based on that I would say its fairly widespread.
One guess is as good as another when availability will come back. Its all a crapshoot these days. I know that the paint area of Flint assembly was upgraded dramatically a few years ago, many millions of dollars were spent to modernize it, but still no two tone availability ?
Edited by 64BAwagon
I know.  The blue AT4s from the last few years look great.  Would love one with the updated interior and gas powertrain.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,361 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
