My research so far says springs are different, and no spring stops for the added pack of additional springs, im curious if the bolts go all the way through the frame for the stops.
I would suggest contacting whatever dealer or online seller you plan to buy from. As you can see due to the generic diagram it’s not clear what exactly comes when you order the spring set. They probably can tell you.
I would suggest buying heavy stuff like springs from your local dealer if there is one that comes close on total price (part plus shipping). That way you know it will arrive undamaged and you can pick it up when convenient.
The stops and bolts obviously are sold separately from the springs. The nut for the stop bolt attachment to the frame was not readily visible. It wasn’t clear to me from MTU’s messages exactly what the nut arrangement is. It’s either a free nut recessed in a tube I could see within the frame, or there is a nut welded into the frame at the end of the tube.  The fact that the tube is there makes me think there’s a free nut in there. I’ll get a mirror tomorrow and see if I can look into one of the frame tubes and see the nut arrangement.
I crawled under my truck to look at how the overload bumper bracket bolts are set up and what the access looks like.
The rear bracket bolts have free nuts and washers inside the frame and access holes allowing you to get a socket on the nut. You would probably need to remove the shock on one side for adequate access to one of the nuts. The first two pictures show the hole in the frame and the nut inside the lower hole.
The front bracket bolts are different. They have welded nut plate arrangements of some kind on the inner side wall of the frame tube with an internal support tube to prevent the box frame tube from being compressed when you tighten the bolt. The big question is whether the 2500 frame has these welded nut plates. Reading MTU’s post again, he said the frames are the same but they left out the bolts, so I suspect the nut plate/tube parts are there. You can’t see the left side nut plates because the tank is in the way, but you can feel them. The right side nut plates are easy to see if you get under the truck and look from the center at the center facing wall of the frame. The third picture shows one of the nut plates on the right side.
Exactly my concern, i was wondeRing if the bolts went all the way through the frame.
Did you see my post immediately prior to this one?
My springs are 2005, no overloads.
the front stops look like 3 hole and the rear 4? Is that what you see?
Yes. I didn’t look at it carefully enough before. 4 bolts per rear and 3 per front stop bracket.
so the tubes are only on the front? and the front has 3 bolts. I don't have those tubes and won't re engineer. I greatlly appreciate your time walking me through what you have.
My camper arrived yesterday. still waiting on the tie downs.
Edited by Hoginedgewood
3 hours ago, Hoginedgewood said:
There would be some benefit to switching to the heavier springs even if you don’t install the overload springs. My understanding is that my spring pack has an extra leaf relative to a 2500.
https://www.generalspringkc.com/leaf-springs/chevrolet-gmc/chevy-gmc-truck/3-4-ton-20-2500/2011-2018/
so this site has 2700 and 3400 lb leafsprings for my 22 2500HD, how do I know what I currently have is rated at?
Those are aftermarket I assume.
Your oem springs would be rated at least as high as your RGAWR, but beyond that I don’t know. Your best bet may be to ask forum user MTU.
called general spring, he wasn't sure where they get those numbers but says 2700 = stock.
i'm sure empty ride quality will suffer, but looks like direction i'm leaning.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
