On 6/5/2024 at 11:24 PM, Qway said:
and also what gauge should I aim for if not factory?
 Hey Qway any luck? I’m having the same problem.
  • 7 months later...
4 Gauge is perfectly adequate for the job
  • 4 months later...
I had this issue a few years ago.  2019 AT4.  Suddenly, start up to no power steering. Same codes etc., somewhat intermittent.  Took it to the dealer, two days later they called and told me needed a battery, which was ridiculous because there was no issue with the battery.  They told me that battery was weak and GM manual said first step was to replace the battery for $600.  I asked what if there was still an issue.  Next step was to replace the power steering module, then if no go, the rack.  So we were looking at thousands of dollars.  I told them no thanks, and got the truck home.
I looked through the basic wiring diagram (power steering is all electric, no pump) and noted that all the codes notification seemed related to the same module and that module shared the ground in question.  Interesting.  Put a jumper cable between the negative pole of the battery and a spot I cleaned up on the frame, viola, no issue.
Remove the extra ground, same issue.  I was not happy.  Found the ground wire, in similar shape to the ones pictured in the chat.  Not sure what genius decided to put an unprotected braided strap right behind the wheel well were all the salt and splash would of course inevitably trash it.
Took it back to the dealer and had the mechanic who diagnosed it come out to the lot.  Plugged in the jumper cable, of course worked fine.
Really not cool they were taking me down this $$$ road.
Changed with the factory strap only because I was marginally out of warranty and was sure if there was an ongoing issue they would somehow say I modified something, but later coated with some dialectic grease just to get a few more years out of it.  At this point a $6 short #4 battery lead would not only work fine but probably last longer.  Braided I feel was used so that movement/vibration would not fatigue the wire over time, but rust beat out any fatigue issue.
Just wanted to share this for anyone else who encounters this issue.  If the cable was changed, be sure the terminal mounting points are clean as they can be pretty rusty as well.  If in doubt, add a supplemental ground to check and or get you home.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
