1 hour ago, Darrell 59 said:
Does anyone have the min thickness for the brake rotors?
Standard 4 piston brakes (w/o optional 6 piston):
Front Brakes
Rotor Discard Thickness - 28.0 mm/1.102 in
Rotor Minimum Allowable Thickness After Refinish - 28.5 mm/1.122 in
Rotor Thickness (NEW) - 30.0 mm/1.181 in
Rotor Maximum Allowable Assembled Lateral Runout - 0.05 mm/0.002 in
Rotor Maximum Allowable Scoring - 1.50 mm/0.059 in
Rotor Maximum Allowable Thickness Variation - 0.006 mm/0.00024 in
Rear Brakes
Rotor Discard Thickness - 18 mm/0.709 in
Rotor Minimum Allowable Thickness After Refinish18.5 mm0.728 in
Rotor Thickness (NEW) - 20.0 mm/0.787in
6 piston accessory big brake kit (option code 5JL if ordered as LPO) :
Front Brakes - 5JL
Rotor Discard Thickness - 30.0 mm/1.181 in
Rotor Minimum Allowable Thickness After Refinish - 30.5 mm/1.201 in
Rotor Thickness (new) - 32.0 mm/1.259 in
All brake rotors have a discard dimension cast into them. Replace any rotor that does not meet this specification. After refinishing the rotor, replace any rotor that does not meet the minimum thickness specifications.
Rotor Maximum Allowable Thickness Variation - 0.018 mm/0.0007 in
