I have a 2019 Chevrolet Silverado wt 4x4,  I had the 2 inch level kit installed and I have 275/65/18 tires on it now and was wondering what would be a good tire size to poke out some for looks. So what tires should I get installed?
Whatever YOU think would look best.
Me?  Poke = more dirt, mud, chance for stone chips on the paint.
You'll get other replies for the size you've got now, for maybe one step up, 22x12s with 33, etc.  Varies quite a bit.
Might be worth a cruise through 76 pages of the T1 wheels thread, see if something catches your eye:
Edited by newdude
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
