Here is some backstory on my 03 Silverado 2500HD crew cab, I had a lot of leaks. 3rd brake light, drive side cab vent (between cab and bed), windshield (top center was leaking in due to glue failure), driver side mirror and driver door. I have fixed all but the driver door.  So I replaced the door seal that did not fix it. I then put the foam insert to "stiffen" the seal and bent the flange towards the door more to get better contact. That helped but did not fix it. Took the door panel off and found a lot of water coming into the door. Weep holes are clear, water deflector plastic has lost most of the adhesive so I used gorilla tape to seucre it. It's still coming in.
Is this a normal amount of water to enter the door?
How do I fix this?
Edited by dmax03
Title change
  • Sad 1
  • dmax03 changed the title to Cab water leak woes - Need help
So, using a dollar bill close the door with the bill between the the seal and the door. Pull the bill out, it should have a reasonable amount of drag on it it it doesn't (you found possible leak sites) here's a few things you can do: Check the fit of the door; is it outboard of where it belongs? The door should be flat in it's home, where the trailing edge of the front fender meets the leading edge of the door; this should all be in the same geometric plain, same as the trailing edge of the door and the edge of the cab. If that's messed up you got major problems; I suggest using some kind of 1/4" or so foam under the door seal so as to make the door seal overall thicker.
You can pull on the window section of the door (window down first please) to bring that part of the door closer to the seal when closed.
Dew wipers: these are stapled to the door inside cover and (somehow) attached to the door on the outboard side of the glass. These are available at many outlets, I would start with www.rockauto.com for the parts if you like or to get the GM P/Ns from their listings and then do a Internet search of those P/Ns. You'd be surprised to learn who sells what. If you think the mirror is leaking I would suggest doing a seal job with either some sort of home made gasket or some RTV or a combination of that. But, here's the thing, GM designed that door to NOT leak; unless the truck has been in an accident regular replacement parts and fix it techniques/solutions ought to fix it. So, stick with those until you have exhausted your options; heck, a bone yard door may be your fix, the hinges on these trucks are welded so there's little in the way of adjustment at those points. Gorilla Glue isn't your best option, try looking at the 3M catalog on line or calling the local body shop supply houses for products and advice on what adhesives to use. Remember this: the garden hose will put a lot more water on your car than a real rain would (unless your nearer the equator, but your not so....) a deluge might come through but a real rain might not. We used to dream of a smoke producing gadget that would help us find leaks on doors, theory was the smoke would be pulled out of the car through the leaky gaskets, I donno if that would work or not but it was a hope that remained unfulfilled.
I would love to hear how it works out for you.
Edited by dna9656
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
