2015 6L80 GMC
140-ish K
Last week, driving home noticed my RPM's were higher than they should be at 45 mph.  Dropped back a couple of gears, and they didn't go up until I got it back to 3rd.
So I assume it was stuck in 4th.
Then noticed it would rev way up before shifting, like 4500 RPM, even just barely accelerating.   And didn't seem to shift past 4th.
Got home, checked fluid, didn't look/smell burnt, wasn't too dirty.   Checked the code, P0741.   Did the usually "check the internet" and found it could be anywhere from the solenoid actually sticking to the tranny is shelled.
So cleared it, and all symptoms immediately went away.  Ran perfect.
Today, coming home from the same place (I go every Wednesday)    I've been watching it now, so I noticed when it happened.  I came off the highway to a stop.  I didn't notice it revving too much when I shifted, but noticed immediately after accelerating lightly that it was turning too many RPM's for the speed again.
Tested right then while driving.   P0741.   Cleared it while driving.  RPM's immediately dropped to where they should be, ran perfect all the way home.  Fluid still not too dirty, not smoked.
Oh, and my Wednesday customer is a dealership where there's a GM tech, he checked the fluid while I was there and also agreed it's not burnt and not excessively dirty.
So what am I seeing here?  Is the converter getting ready to join the Church Triumphant?   Is my TCC solenoid just actually sticking and maybe I should change the fluid?   Something in between those two extremes?
  • 2 years later...
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
