Unusual exhaust noise
I took my truck in to the dealer and they said they couldn't find where the noise was coming from, and that they had checked the diff fluid level and everything looked fine. Told me to take it home and "we'll see if anything develops".
So, maybe someone here can help.
The sound is like that when you blow across the top of a beer or coca cola bottle...it is only under acceleration and occurs no matter what gear you have it in including park. I can be going down the road, shift it into neutral and give it some gas and still get the "foghorn" sound as my son calls it. It is only when I'm under 35 mph. It is only for the first five minutes when driving and then goes away. Has anyone else experienced this?
Sounds like a heat shield. Once everything warms up and expands it must be going away....
Some people have put some fire-proof insulation in between their shields and the exhaust to keep them from rattling.
I have some barely noticable resonance (radio off/windows up) when my truck passes through the 1500-1800 RPM range.
Well I'd say get your son a sailor's cap for when he rides up front, but that won't solve the problem. Sorry, was just in a good mood(despite the cough/sore throat) from listening to a little Cosby. I just laugh when we all try to describe some of the noises the vehicles make from time to time. I hope it gets worked out.
I hear ya...I couldn't explain the sound until my wife said it sounded like blowing across the top of the bottle. It fit and I used it....
  • 2 years later...
I still have this issue with my 2004 Crewcab 2500 LD w/6.0L exhaust.
Anyone else find the problem. Dealer says they cut the system and install a flex tube to cure it. Doesn't sound like a fix to me. More like a band-aid.
Others experience this or find something that works?
are you shure it's exhaust and not the intake makeing the sound.
if it's in the exhaust i would say it's misalighned parts kinda like when you take 2 blades of grass and blow through them or paper and it vibrates and makes that sound. intake is also good for makeing them foghorn sounds.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
