I have a clunk that has recently shown up mainly when turning and going over uneven road grades. Not sure where its coming from. Thought it was the tool box in the truck but eliminated that possibility by removing it. I got into the  bed of the truck and bouncing and shaking the truck recreates it somewhat. Still no idea where its coming from. I have 4200miles on the truck and its only been happening for about the last 1000 miles. Anyone else dealt with this?
Edited by Bstevens1084
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
