I am removing the front brake rotors from my 2008 4.8 Chevrolet Silverado and the torx screw broke inside of the rotors and I can't remove the rotors, can I drill it out?
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 856 Guests (See full list)
