I got caught up in a heavy downpour today and switched from 2WD to Auto, when i got home i tried to switch back to 2WD mode and the display is now stuck
in "4WD shift in Progress".  Any thoughts?
As said above drive a short distance, what happened was the drivetrain was still under pressure and it won't disengage until pressure is released.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
