It could be the hood latch. Or it could be a malfunction with one of the systems. You really need to check for a code. I know when I had a problem with 1 injector, the remote start wouldn't work.
1 hour ago, Hans A Rasmussen said:
My remote does not work. I push lock button then hold down remote start button and the running lights flash but does nothing?
Parking brake is on?
Thanks
Welcome to the site.
Need more info on the truck, my guess is you have an active CEL, if so, it is a built in safety feature and disables the function.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
