Alright… I’m in over my head, i took my truck to 2 different mechanics, one said it might be exhaust manifold leak so I changed that, other said it was a bad lifter, opened it up and lifters are operating properly! Symptoms are as follows…
- Ticking sound seems to be from left side of motor
- Check engine light with misfire in cylinder 5
- 120 pressure on cylinder 5, others have 200
- When reving engine the ticking is louder, it’s more of a deeper tick
Any insights or if someone has had this problem I would greeeatly appreciate it!!!!
Did you remove the lifters or just look at the pushrods and rockers moving up and down?
The ticking could be a bad lifter that wiped out the cam lobe.
If it is not a lifter/push rod/cam issue, another problem could be a leaking injector seal in then cylinder head, this is a direct injected motor, the injectors spray directly into the combustion chamber and could account for the lower compression.
AFM cylinders on the 4.3 are cylinders 3 and 6.
Sounds like you've got a bad camshaft and lifters on cylinder 5.
    tblt44
    tblt44
  • Who's Online   2 Members, 0 Anonymous, 526 Guests (See full list)
