I have 2003 Sierra 4.8 with the 4l60e and when shifting from 2-3 it flares. Not much just a couple hundred RPM but definitely there. Is there any way to fix that?
    • Correct.  2019-2021 model years are serviced by a different p/n.  19420611.  Recall 2021s use 19420611.   The recall engines 2022-2024 model years are serviced with 12740076.     The difference between 19420611 and 12740076 is GM changed injector size for 2022.  The injectors are smaller on 12740076 with smaller injector bores in the cylinder heads to match the smaller injectors.  So you can't install a 19420611 in a 2022-2024, and you can't install a 12740076 in a 2019-2021.     Both engines are the replacement engine p/ns that are in the L87 recall.  So both of these are the updated engines.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
