92 k1500 4x4 problem, help.
My friend has a 92 chevy 4x4 1.2 ton with the 4x4 shifter on the floor. Every time he shifts to 4 wheel drive it will not engage and it blows a fuse. Does anyone have a wiring diagram or an idea of what could be wrong? :thumbs:
