Cracked Mirror
:thumbs: I have a 2002 Silverado and I live in NW PA with alot of temperature variation in the winter, but I have never had this problem with any other truck that I have owned. I have had a hairline crack in the pass. side mirror and had that replaced, now I have both mirrors with hairline cracks. The mirrors were not hit by any object. Anyone have a similar experience??????? :devil:
where did they crack?
My pass. side is cracked underneath. My reason is that I hit a basketball pole with mine. I have a new mirror but I havent put it on yet. I did have to change the glass because It fell out and busted
My passenger side mirror cracked and was replaced. It was cracked due to the temp inversion caused by the heating grid. Its the same thing when your windshield cracks in the winter after a rock hit the window only in the mirrors it doesn't need an impact to start the crack.
The one side is cracked in the middle while the other is toward the bottom. The diff. in temp. when the heated mirrors are turned on seem to be the cause. I just hope the dealer doesn't give me a hassle over 3 replacements.
Maybe GM should consider a better replacemnt mirror material.
    250.3k
    Old Bay
    Old Bay
  • Who's Online   4 Members, 1 Anonymous, 924 Guests (See full list)
    • I know when I was looking around last year to see if someone handled Amsoil gear oil to buy at the retail level which of course means full price. I found an independent shop that works a lot on GM/Duramax pickups and they did not bring in the 75W-85 as they just stuck to the 75W-90 for the front and rear as a standard practice for the HD trucks which makes sense anyway for the higher hp/torque diesel and pulling heavy loads in four wheel drive. I haven't changed my diff oils yet but still plan on using the 75W-85 for the front diff as I highly doubt I will be beating on the truck and figured for my use type the bit thinner oil would be to my benefit for the winter for that slightly less drag. Very different weather here all winter vs northern Washington near the coast, that's for sure.
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
