Hello, my name is Raymond and i have a problem i can't solve.
my car keeps giving me trouble codes (po302, po401 and po452).
i replaced the egr valve and tubes and tested the connector.
i replaced the coils and sparkplugs and cables.
i replaced the tank pressure sensor.
the car doesn't go through the emission test ;(
i hope  someone here can help me out.
I would concentrate on the #2 misfire.
EVAP is an emission-only thing and shouldn't affect operation, unless a purge valve is stuck open and making the vehicle run either pig rich, or very lean.
Bad EGR components can cause a rough idle.
Did you have any of these symptoms? If not, you just fired the parts cannon - you'd have been better served burning your money for heat.
Does the vehicle actually have a misfire? What's compression on #2 if it does? What are your fuel trims at idle, cruise, and full-throttle? What were the symptoms regardless of the codes?
    Enduro73
    Enduro73
  • Who's Online   6 Members, 0 Anonymous, 1,266 Guests (See full list)
