I have a 2024 silverado 2500 that I recently just recently paired the TTPMS 4T+ sensors,my problem is they will only stay paired for about 2 hours of a trip before they unpaired. Has anyone else had this issue? I'm not reprogramming them everytime I use my trailer.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 524 Guests (See full list)
