Starts up normal. Few seconds something seems to click on or off and the pressure goes from 40 in the middle to around 60, then starts to shake and run rough. Put in a new gm fuel injector. Swapped around the spark plug, coil pack and wires. No change. compression check showed 150-160.
Not sure what to do next, maybe take off the valve cover? Ideas
thanks in advance 🤙🏽
Yup, time to pull the valve cover and check the valve springs and see if that lifter is moving the rockers up and down like normal.
    Charly
    Charly
  • Who's Online   0 Members, 0 Anonymous, 6,560 Guests (See full list)
