Came across an old post on here with a guy replacing his factory bose sub with a loaded kicker under console box. Anyone know where I could get one? I know it's old. Thanks for any help. spacer.png
You have to build you own bud. The guy that made those boxes went dark some time ago. Or you can pay a mint for a stealth box with a 10" sub.
Depending on the year of your truck JL Audio has a custom one that fits under the console.
 https://www.crutchfield.com/p_13694645/JL-Audio-Stealthbox.html?tp=113.
Have you looked into the plug-and-play 10" Kicker that mounts under the rear seat? I have this one in my 2017 and it sounds great.
  https://accessories.gmc.com/product/200-watt-subwoofer-kit-by-kicker®-associated-accessories-19303118?bac=320958&body=Crew Cab Pickup&bodyId=22&bodyNumDoors=5&bodyNumDoorsId=5&categoryId=12319&make=GMC&makeId=48&model=Sierra 1500&modelId=548&year=2017
Edited by UrbanRage
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
