--Engine Ticking, New Truck--
im just wondering, what have any of you done to make the ticking noise go away (if you ever had it) such as the one my engine makes. 1700 miles on it only :devil: . did anyone have the dealer fix it or did changing oils help out. I read past posts but nobody said what theyve done about it. Thanks, will appreciate any responses.
Describe your ticking. How loud is this ticking, does it accelerate with engine speed, is it only at startup? Mine has cold start knock and a barely audible ticking at idle no matter the temp, but im pretty sure the ticking is injectors or maybe the valvetrain. Running 5 quarts conventional oil with 1 quart full synthetic and a bottle of prolong the csk is pretty minimal now whereas it used to be kinda harsh sounding, it only bothers me occasionally now. I wish i had tried the two things seperately as i don't know whether the prolong made a difference or the 1 quart synthetic.
I don't know if the prolong does what it says it will do but i do remember watching a tv show once where they were doing nothing but testing it. It was some weird stuff, they were running an engine on a stand without and oil pan throwing sand and water all over the bottom end. You could see the crank spinning, i guess it was running about 3000 to 4000 rpm, and the motor never skipped a beat. :devil: Plus they had a car driving all over the place with no oil pan. I have yet to abuse test it myself, i have some extra in my truck still in the bottle i plan to test.
In my opinion they will probably always be some csk. The engine is cold and the metals expand at different rates causing the noise, so its no big deal, i just don't give it the coal until it at least partially warms up. Just my personal experience, hope it helps.
Its a light ticking, and it ticks whenever its idle, cold or hot. revving the engine in park makes it dissappear, so im guessing its not a knock, but i never heard a new engine make this sound before. I never really paid attention to any other gm engine sounds.
My guess is that you are hearing the injectors or valvetrain. Wouldn't know exactly without hearing it but thats what it sounds like. I would say don't worry bout it, but someone else may have some more knowledge on this. Anybody?
I have the 6.0, and I noticed what appears to be loud engine noises-ticking and such similer noises... I have written it off to the "plastic" intake manifold not containing the noise as well as a metal one.
Do you live where it get's real real cold???I notice my 03 has injector tick when real cold and when it warms up over 30 nothing... :devil:
I was just going to post about my tick, or rather how it has disappeared ... for the last couple of years (am at 32K now) my 01 Hoe has had a (single) low level tick all the time at idle no matter whether cold or hot; but, within the last few weeks there has been absolutely no tick whatsoever. The only thing that changed was using a synthetic other than Mobil1 since they were out at the time.
  • 6 months later...
I'd like to take a stab at resolving this on my truck.
My tick seems to be consistent with RPM. Its a single tick, and when I counted them in 30 seconds, it was about 300, which corresponds roughtly to the 500 or so RPM at idle.
Increasing the RPMs makes the tick increase to the point that it either stops, or is masked by the other increasing engine noises.
My engine does not tick at startup. The tick begins once the truck warms up, and then never goes away. I believe this would rule out the cold-start-knock.
I can't hear it while driving normally. I do hear it when the noise reflects off a curb or wall. Its very embarassing going through the fastfood drive-thru. Sounds like the driver side, but its difficult to locate precisely. The tick is a sharp, distinct, hard-sounding noise with a medium-to-high pitch.
It seems like the tick got worse when I changed the oil last weekend, but I really wasn't paying that much attention before (I had the infamous driveline clunk captivating my attention up until I changed the yoke last weekend). Plus, up until last week, it was so hot I had the A/C on all the time with the windows up.
My guess is that its either lifter or valve noise. I'd really like to get rid of it, but not if I have to pull the heads to do so.
Any suggestions on how I could narrow down the source and/or address it?
My best guess is its a lifter. I theorize that one of the orifices may be partially clogged. When the oil is cold, it doesn't move as fast, but when the oil heats up, it drains out faster than the lifter can be refilled. I figure that if it was a valve, it would tick all the time. Or, perhaps the checkball isn't sealing properly.
I have good oil pressure according to the gauge (never below 1/2, which IIRC is around 40-50 psi).
I'm using the recommended oil, which I believe is 5w-30. 10w-30 is recommended except in cold weather (IIRC). Maybe I should try the thicker oil and then make sure I change it before winter?
GUYS.....My 01 as well as my 04 has the tick ! Quite annoying
at a drive thru ! All new GM trucks have roller rockers so a
lifter tick is almost impossible.
The tick your hearing is fuel flowing thru the rails and injector poppets.
A mechanic whipped out a stethoscope and let me hear for myself
when I took it to the dealer.
You won't really notice it off idle because the engine is roaring or ya got
the stereo up LOUDER !...............LOL !!!!!!
NOT to be confused with CSK !
Thankfully which my 04 does NOT have.... :cheers: .....geo
When I bought my truck, the dealer (or shall I say service manager) went so far as to tell me that I would hear ticking. Of course, I kind of already knew to expect that, I guess some people get concerned. It is the lifter tick, as they are hydraulic and they have to pump up with oil. It it loudest for the first couple of minutes after starting the engine, cold or hot, and should get quieter thereafter, although not quite inaudible. As long as I have had a Chevy, the engines have always done this, It did it on my '69 C10 and it does it on my '02 1500.
After all, doesn't Chevrolet stand for Can Hear Every Valve Rap Out Loud Every Time? :cheers:
So in short, that is normal, assuming that this is the ticking that you are hearing.
And Rocker arms and lifters are totally independant other than the fact that they work together to move the valves through the use of pushrods. I don't know of any hydraulic rockers, only roller tip rockers and flat tip rockers.
my lawnmower did this new. it was a kohler engine. sears said ITS normal noise.it was a lifter push/ :cheers: rod on noise. i changed to synthetic 5w-30 and it went away.i think if you change oil to lighter grade like 5w-30 dino or synthetic and get a few more miles on it,hopefully it will go away. i dont know if warranty will cover if you do it but thats what i would try.my dodge did this for say 12,000 miles and it disappeared.but i changed to 5w-30 synthetic.i dont know if that made a difference or things just got better.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
