Truck had been running however when starting warm did not start right away. replaced battery then would not start, backfires thru intake. ideas?
relearn and / or replace camshaft position sensor?
did not see codes before i replaced battery.
Check the distributor cap  and rotor for water, carbon tracks, if thats ok see if the rotor still points straight forward with the timing marks lined  up, the timing chain may have jumped
