AC problem with split system. Passenger side cold driver side hot. Both are cold until the engine reaches normal temp.
6 hours ago, John Alzheimer said:
It appears your problem is as perplexing to you, as your post is to us.
This may be your issue.....
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
