My Dad owns a 2015 GMC Sierra 1500 Denali with the 5.3 engine package. A few back he noticed the truck wasn't cooling like it should and after checking the low & high side pressures decided to add a small amount of freon. When I say small I mean small because all it took to get the truck acting right again was about 5-6 oz of freon. Fast forward 2 weeks and now he is back in the same boat again and has began the process of tracking down the leak. The first place I looked was the AC Condenser but luckily his hasn't broke at the top corner like many others have experienced. Today I had my HVAC freon checker/sniffer out going over the truck and every time I passed over the left side of expansion valve it went off. Does anyone know if these Expansion Valves are known to leak here? The freon checker didn't go off when I passed over the o-rings where the cooling lines connect, it would only go off when I passed over the left side.
Thanks in advance for any help you can give.
When the system does not have pressure, unfortunately the expansion valve. It has two o rings.  Replace them.  You can use a heavy mix of soap and water to verify the leak. If bubbles are present with the system pressurized, then well.....
I followed your advice which I appreciate but now I have another question.  As you can see in the photo below when we sprayed the soapy water on the expansion valve bubbles appear.  If I turn off the AC off but leave the fan running bubbles appear.  If I turn my fan & AC completely off the bubbles stop which I don't understand.  The AC system in our truck is currently charged and working properly.  Why would the bubbles stop the minute I cut the fan off if the expansion valve is leaking especially in a pressurized system? Is there any chance the air coming off the evaporator blower is passing by the expansion valve causing these bubbles?  I guess if I put UV Dye in it would answer my question but I thought I would throw this out there.  With the amount of bubbles I was seeing I wouldn't think a system would hold freon more then a day where this one is lasting about 2 weeks.
Once again thanks for the help
If it only leaks while fan is running but not when compressor is running sounds like  a simple plenum leak, not refrigerant
The bubbles are present if I spray soapy water around the expansion valve then turn on the AC on.  The bubbles are also present if I spray soapy water around the expansion valve and just turn the fan on by itself.  The minute I turn the AC & Fan both off the bubbles stop.  Maybe I'm wrong but I would think there should be bubbles all the time if the expansion valve is actually leaking.
Thank you for offering to help us.
Edited by GovtMule66
spelling
I would think so too. It would appear to be an air leak. There has to be some kind of seal or sealant where the X-valve penetrates the firewall
On 9/22/2025 at 9:25 AM, phatrabbitzz said:
@GovtMule66did you ever figure this out?
My Dad ended up having to replace the A/C Compressor along with the A/C Condenser which cracked in the same spot as other GM owners.  Since we had the entire A/C unit basically torn apart we went ahead and replaced the expansion valve as well.  I'm sorry I don't have a better answer for you.
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 473 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
