As part of replacing my Compressor, I ordered a drier assembly.  What I fount was that the GM receiver drier assembly didn't fit into the tube on the condenser.  Turns out the tube on my condenser is 14 1/2 inches long and the drier assembly is 17 1/2 inches long.
In 2021, I couldn't find the leak and took it to a shop I had done business with in the past.  They found the condenser was leaking (big surprise).  I told them to go ahead and replace it.  He did and everything was fine.  It would appear he got an aftermarket part that fit, but all he know is he got it from a local parts supplier.
When I found a replacement AC Delco condenser online for $170, I ordered it.  The part was advertised as
ACDelco Gold 15-63889 (19383805) Air Conditioning Condenser with Automatic Transmission Oil Cooler
It didn't indicate it came with the drier, But I already had one.
It came in a box with an official looking 'AC Delco Professional' label and the condenser had an 18 inch tube to hold the desiccant. I'm all set.
This is where I got myself in trouble
When I went to install the drier, I found a plastic plug held in place with a snap ring.  I removed the snap ring but I couldn't pull out the plug.  I finally got it out with help from a slide hammer and found it had 2 green o rings holding it in place.  In the tube was a Desiccant bag.
Here is my problem:  I destroyed the plastic plug by using the slide hammer.  There are no threads in the tube to allow me to install the GM Drier assembly.
Does anybody have idea where I can find a drier assembly with just a plastic plug and no threads?  Should I have been concerned when I received a box that had been opened and resealed with official online marketer brand tape?
I just spoke to AC Delco support.  AC Delco Gold is for aftermarket parts, not original equipment.  All she could tell me is that she could find several notes from dealers regarding 'fitment issues' for this part number.  She couldn't tell me what the issues are, for that I would need to speak to a dealer.  She also couldn't give me a part number for the AC Delco Gold Drier assembly
I went to the AC Delco website, but, I keep getting 'There has been an unexpected error, please try again later. when I try try shop the GM Parts Store.
I got it all back together and it appears to be working.
On to the next problem.  I have 50 degree air coming from the passenger's side duct and 70 degree air coming from the driver's side duct.   Score one for the dual zones.
I believe the next step is to pull apart the instrument panel to get access to the Air Distributor Case.  At least I don't have to pull out the entire HVAC  module.  I would appreciate any input from anyone familiar with this particular device.
Also, can anyone direct me to GM document on expected Hi and Lo side gauge readings?  The internet has plenty of opinions that don't necessary agree with each other.
Joe,
Just saw your post and I have the reverse problem AC only cold on passenger and now not AC on either side. I just replaced the driver side blend door actuator. Its like ~$30 and you can replace it without removing the entire dash but it is not a fun task to do. If you follow this video it covers just about everything you need to know about this problem.
  • 3 weeks later...
Thanks Jacob,  I'm a little behind with my responses.  I ordered the part referenced in this video, just haven't had time to install it.
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,425 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
