Heated mirror broke
My drivers side heated mirror no longer heats/defrosts on my 2000 Z71. Am I just out of luck and the mirror is simply in need of replacing or is there some sort of fix for this?
Seems to be a common issue, I had my drivers' side go out and just got the truck out of the dealership after having the power steering pump replaced and midshaft fixed, only 800 miles left on the 39k warranty and the passenger mirror farted out on me...good thing they fix it quick. Not sure what the costs are otherwise.
Hey Ideeho, why did your power steering pump have to be replaced? I'm just curious because I've been having problems with my power steering going out low rpms when I first start the truck and take off. Dealer can't find problem.
On our 02 Tahoe the passenger side went out and then the drivers side blew up. You could littlerally here it when the drivers side went off. All it did though was crack the glass and leaked green oil all over the side of the Hoe. Luckily dealer fixed under warrantee.
Boy, I was hoping it would be an easy fix. Maybe I'll try the salvage yard first as the new GM part is likely expensive. I guess I could run right into the same problem again, though.
