Here's one for you guys. I'm having a hard time diagnosing this sound and am really hoping someone can help. I have a 2010 Sierra 1500 with 4.8 and 4L60E, 2wd.
I've never heard a sound like this come from a vehicle before. It sounds like a massive old wooden door groaning. Not a squeak but a low guttural groan.
Here are the symptoms
-groan when accelerating hard off a stop, through 1st and a little into 2nd
-If I'm light on the throttle taking off it makes no sound
-truck in drive, foot on brake, it will groan when given gas
-no noise in reverse
-no noise at speed
-different rpm does not change the sound it makes
-might be worth noting I have what I think is excessive driveshaft rotational play when parked. Like it can be rocked back and forth too much. U joints appear good
Something is not happy when the powertrain/driveline is torquing up
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
