My 2020 GMC Sierra 2500hd tires rub the sway bar.  37x12.50r20.  I just bought the truck and they came on it.  What size spacer do I need or do I need to go with a smaller or narrow tire.  I like the look of the 37.  What is the biggest tire I can put on without a spacer?
  • 5 months later...
