Navigation for 04 silverado
i have a 04 silverado with bose and i bought the factory navigation head unit out of a 04 escalade installed in it and everything pluged in fine i started the truck but it said theftlock activated i then took out the radio fuse under the hood while the truck was on and put it back and the nav worked perfect no problems then i started the truck and it locked again can someone please help me i really dont want to go to the dealer would appreciate any suggestions
Hey you are going to have to get it programmed I imagine with the tech 2. Please let us know how it works out as i was thiking about this a while ago my self. I think I scrapped the idea because you will still need a seperate cd player...is this correct? Let us know what happenes and post some pics of it installed if you can!
actully when i had it working it works as a single disc cd player but if you wanted you could get the 6 disc from a escalade or denali and mount that in the center console to but no extra cd player is needed
If the radio was able to come on without the theftlock, you will probably have to go to the dealer or find someone with the Tech2 programmer to code your VIN into the NAV radio. If the radio, locks immediately, you will have to send the radio to a Delco repair center to have them reprogram the radio. :lol:
if you could post some pics that would be great. I have been trying to locate one of those units for months now. Where did you come across it? how much did you pay?
Hey were you ever able to get this to work? I would like to try it if I can track one down (no luck yet) I upgraded to the 6 disc but would not mind the single disc if I could have the NAV. I thought I read somewhere that there were sensors elsewhere in the vehicle that contributed to the NAV working...or is it fully self contained in the head unit?
Inquiring minds want to know!
Yes they do!!! I wanna know!! :)
Hey guys I did some more searching myself and this is what I have come up with! I realize this thread may be better for the audio forum, but since its here already I hopes it ok!
I PM'd the original poster but never heard anything so I called around. Apparantly the NAV units are not available for sale to the general public, but it doesnt matter because from a dealer you would be looking at around $3000!! Uhh yeah...3K!!!
Another option is always eBay right? Well yes it is and here is one for sale...have a look see....I just can not justify this cost right now! Guess I will stick with my 6 disc in dash and $1.49 gas station map!!
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2462472909
You can see the part number and after trying GMPD and other big factory radio outlets I have discovered that it is not available! Not ready to plunk down this much cash for a unit that may or may not work ok in my truck and may be a pain to setup and work...but ohhh its such a cool headunit!!!! :thumbs:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
