Hey Guys I could use some help. I have a truck that new to me that I'm trying to diagnose an occasional hard start on. It's a 2022 silverado with an L8T. That has gotten worse over the last 3 months of ownership. Truck starts fine except after its been sitting for about 2hrs. Then I have long crank times. Truck start fine in the morning though. I have no "CEL", but a p2635 fault. I'm dropping fuel pressure and will set a code if I run the ****** out of the truck, but only then and it will "clear" itself. Useing the troubleshooting procedure outlined by GM according to the code I've found online. Im using a Autel 808 to Depressurize the fuel system durring a cold idle. After the truck dies the sensor is still showing pressure 30psi-100psi after the engine stops. How would you verify the sensor/wiring vs the fuel control module? And there is it? Its not on the supply line thats visible, but from some videos it looks to be on top the tank by the bulkhead. I still think I might have a bad pump too. At idle the command is 80% (engine warm) and the pump is running a 7k RPMs. Thoughts or suggestions? Not a lot out there on these engines. I also have weak injectors on bank 1. I'm not sure how that could be attributing to my issue.  I hate swapping parts just for the sake of swapping parts but I'm getting to that point almost.
I can try and post some photos of the scan tool values if I can figure out how to resize them.
There are two pressure sensors...one is to control the fuel pump pressure in the tank and the other is on the high pressure fuel rail. I have a feeling your depressurize command is for the high pressure rail but that's just a WAG.`
There is a one way check valve after the tank fuel pump to maintain pressure in the line to prevent long starts.
I have the service manual and there are a number of things to check, You may just want to take to some one who services these trucks or the dealer. Shotgunning parts is going to be an expensive endeavor.
Are you not under warranty?
How do you know you have weak injectors?
Edited by bruceb58
Yes...my WAG was correct...depressurize the high side for the DI.
Edited by bruceb58
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
