I’m looking to add a DRL light and would like to know if there’s a wire up in the headlight connector that powers the DRL lights only. Once the parking lights turn on the DRL should power off hopefully. Any input would be greatly appreciated.
Suggestion.  Purchase something like I have linked below.  It provides you the DRL connection without screwing up your OEM connectors.  I have a couple of these because I added running lights and turn signals to my running boards.  Other companies make these as well so only reference this one because they did me right.
I also think there is another thread here that provides the pinout which includes DRL wire...just be careful if you connect so as not to screw a wire that you need.
https://www.starkey-products.com/products/chevrolet-gmc-1500-2500-3500-silverado-sierra-2022-2023-2024
    Gkistler
    Gkistler
  • Who's Online   4 Members, 0 Anonymous, 877 Guests (See full list)
