I purchased a used 2021 Silverado 2500HD Z71 6.6 Duramax w/ 40k miles, 5 weeks ago from Penske GMC.
Two weeks ago I received a "Service Safety Restraint System" light. Took it to dealer who said I am 2 days past the 30 day warranty period. They said it was the front passenger seat haptic airbag sensor. They are checking to see if extended warranty will cover that.
Yesterday I received two warnings,
1. Service Power Steering Drive With Care, but Power steering feels a little over assisted, power steering fluid is full.
2. Service DEF System See Owner's Manual, I added DEF 3 days ago and truck has over half tank. 98 miles until 65 mph max.
This is my first diesel, any help or ideas will be appreciated. I understand every dealer trade-in was more than likely traded in for a reason, just hoping I didn't make the mistake of buying somebody else' lemon. Truck is unbelievably clean inside and out.
Edited by jasonhooker3
power steering feels over assisted
1. Service Power Steering Drive With Care, but Power steering feels fine, power steering fluid is full.
Our team regrets to hear of this concern with your Silverado and understand how an unexpected occurrence can be worrisome. We would like to take this opportunity to learn more and assist where we can. When you have a moment, please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We look forward to hearing from you.
When the Service DEF system warning first came on, the DEF was at 1/2 tank. I filled it all the way up and warning light went away shortly after. Weird thing is the Service Power Steering warning went away at the same time and the power steering feels perfectly normal now??? When the warning light was on the power steering was very sensitive (overly assisted). The CEL remained on for 3-4 key cycles, and is now off.
  • 2 months later...
Dealer looked at truck and said they found a bad ground wire. Ground wire was replaced, ran great for a few weeks until service def system and service power steering lights came on again, and battery was completely dead the following morning.... Jumped truck, and after 5-6 key cycles, CEL went away. This is the 3rd or 4th time, the service DEF and service power steering lights have come on, followed by a dead battery in the morning. Once I get truck jumped, and after 5-6 key cycles, lights go away and battery is fine for a couple weeks. Timing of this problem seems to be consistent with regen periods???
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 1,372 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
