10% off all Yank torque converters!
We're offering 10% off all Yank torque converters including the Truck Thrusters, Pro Thrusters and Stealth -
YANK TRUCK THRUSTER 2600 (4.8, 5.3, 6.0) (278mm, 2600 stall, 2.10 STR)
YANK TRUCK THRUSTER 3000 (4.8, 5.3, 6.0) (278 mm, 3000 stall, 2.21 STR, 98.6% efficiency!) This converter is a modified Truck Thruster 2600. Being so, it shares the stock-like appearance, super-high efficiency, and impressive towing capacity of its lower stall brother. This is the most aggressive converter for the Truck and SUV enthusiast who still wants to maintain their full factory towing capacity. You should expect your 0-60 and 1/4 mile times to drop .5 seconds!
YANK TRUCK THRUSTER 3200 (4.8, 5.3, 6.0) (245mm, 3200 stall, 2.70 STR) This converter is for the truck and SUV "hot rodder". You should expect your 0-60 and 1/4 mile times to drop at least .5 seconds! The Truck Thruster 3200 will allow over 3,200 rpm stall, with only a 1,700 rpm drop between shifts. This converter has a maximum recommended towing capacity of 4,000 lbs. Should you need to tow more, please consider the Truck Thruster 2600/3000 or Truck Stealth 2400.
TRUCK STEALTH 2400 (4.8, 5.3, 6.0) (300mm, 2400 stall, 1.90 STR) Stock appearing converter. Full factory tow capacity. Stock GM converter with pump and stator change. Drops 0-60 acceleration times .2-.3 seconds.
PRO TRUCK 3000, 3200, 3400 (4.8, 5.3, 6.0)(258mm, 2.4 STR) These converters have upgraded clutches to handle high horsepower applications. They have a towing capacity of 7000lbs
YANK TRUCK THRUSTER 2600HD (6.0 and 8.1L with 4L80E trans) (300mm, 2600 stall, 2.0 STR) This converter is a significant step up from stock, but will maintain all the towing capacity intended for this heavy duty class of Trucks.
YANK TRUCK THRUSTER 3200HD (6.0 and 8.1L with 4L80E trans) (265mm, 3200 stall, 2.10 STR) This converter is for the Heavy Duty truck and SUV "hot rodder". It will allow over 3,200 rpm stall, with only a 1,700 rpm drop between shifts. This converter has a maximum recommended towing capacity of 4,000 lbs. Should you need to tow more, please consider the Truck Thruster 2600HD.
More info can be found in the truck section of our website. Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
This offer will be running through Sunday evening (2/29).
Tom
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
